Old 20-05-2015, 04:52 PM
maxc maxc is offline
Default Re: STEAM or WATER Injection ?
Originally Posted by parmas View Post
You say 325bhp without steam and 360bhp with steam.....
- Are these on a dyno?
- If yes, a graph worth a million !
- When testing the steam effect..... igntion timing, cam timing, fuel etc.. all is left as it is ?
used gtech meter. ignition timing, cam timing, fuel etc.. all is left as it is yes.
Old 20-05-2015, 05:15 PM
http://www.aquamist.co.uk/vbulletin/...ead.php?t=1620
Old 21-05-2015, 05:57 AM
parmas parmas is offline
Nice article and video !
Do you want to share with us in detail what the setup is about as the video is too dark to see well ?
Old 21-05-2015, 05:03 PM
That is not my video. This is me. https://youtu.be/VZmPlTvv7tk
Cam lobe wore out in that engine. The next build the power valve leaked on cam breakin 5 minutes into it blowing blue smoke out the tail pipes. I no longer use carbs with power valves. Don't have money for fuel injection.
Old 22-05-2015, 12:12 AM
Could explain what did you used for the steam injection setup?
Old 24-05-2015, 07:44 PM
See my #7 post in this thread. Simple gravity feed boiler with reservoir mounted on firewall solenoid turning on .030 jet too boiler. I never ran carb booster venturi feed setup.
