I am near the completion of building my mazdaspeed 3. I needed a good WMI kit due to only having 91oct fuel around where I live. After working with Richard I will be setting up my kit for 200hp of fueling possibly more. I am creating this thread to show the power gains and a good install with pictures on a gen two speed 3.This thread will be updated periodically with install pictures and dyno charts of power gains from different mixtures and such.
The WMI kit I will be installing; HFS-4 V3 5 Aquamist jet adapter 4 of them for port injection and one pre TB for cooling 5 .8mm nozzles to deliver the fuel I will need 1 T fitting 1 Hex Manifold 1 Aquamist WM tank 5 Liters with baffle and bracket The motor build as follows: Full machine work, pinning, keyed, port head, bore, the whole works Carrillo H-beam rods Gibtec pistons coated coated bearings and much more Head was ported cams full valve job on 70lb springs with +1mm valves PTE 5862 turbo kit full v band for the break in and base tuning. Later to come in July it will be Twin charged with a TRD supercharger and a PTE 6466 Turbo this is where I was going to really need the fueling to stay up with the twin charge so with this build being said I will be posting pictures and keeping people updated. |
Please update from time to time on progress.
