Old 09-06-2017, 06:05 PM
zakshaker zakshaker is offline
Default HFS3 V2KC default pcb setting
Hello,
I just got hand on a HFS3 V2KC board which was installed on a Mitsu L200 turbo diesel.
This PCB has gone thru few changes.
I would like to set it up back to factory setting (it is going on an evo3 now)
anyone would have a picture of same PCB with default setting ?
Or could you tell me what are the default settings ?
I'm pretty sure the MPS soldering has to be removed, then solder bridge IDC again (I think this has been cut)
now what about CUST, PWM-, PWM+
Then *1, *1.5, *2
thanks
Old 10-06-2017, 08:11 AM
Default Re: HFS3 V2KC default pcb setting
factory:
MPS/IDC ........... IDC linked, MPS cut
PWM- ........... linked, all others unlinked
iDC prescaler .......... x1 linked
Old 14-06-2017, 06:54 AM
Thanks Richard.
PWM- is well butchered, that's worry me !
I'll let you know how it goes
thanks for your help
Old 14-06-2017, 08:33 AM
That doesn't that bad. As long as the pads are there, you will be OK. Perhaps clear the flux with methanol.
Old 14-06-2017, 09:13 AM
after closer inspection, the larger pad just when off the PCB just by contact with finger :/
Anything we could do to sort this out ?
Old 14-06-2017, 12:50 PM
Old 27-06-2017, 08:24 PM
Thanks Richard I will try that then.
I've tried to send an emails a week ago and an other one tosay. have you changed email address ?
Old 05-07-2017, 08:49 PM
it seems to have done the trick. the led blinks again
Thanks for help as always.
I have well received your email, sent two others since then. Doesn't seem to be best way to reach you anymore.
cheers
