Old 09-09-2004, 12:53 PM
mr2j mr2j is offline
Default when should the water be injected??
Hi ive just fitted aquamist to my MR2 and was wondering what boost level i should have the system activate at..
Currently the car is running 14psi and the water is activated at the factory set 10psi......
also.... which way do i turn the screw on the pressure switch to alter the activation point :? :?
any idea's welcome :smile:
Old 09-09-2004, 03:02 PM
dsmtuned dsmtuned is offline
I don't know which way you turn the screw, but I think you'll just have to test around and see what boost level for activation works best for your set-up.
You're probably in the right area right now with the trigger at 10psi.
-Craig
Old 09-09-2004, 03:19 PM
Cheer's mate... ill give a twiddle and see what happens
Old 12-09-2004, 10:05 AM
JohnA JohnA is offline
You can install an LED across the terminals of the pressure switch mate. The activation point will be obvious then.
John
www.max-boost.co.uk
Old 22-09-2004, 10:44 PM
Default Re: when should the water be injected??
From the factory preset point of 10psi, 1/4T clockwise will increase the triggering point by 2.5-3psi. Reverse effect when rotatng anti-clockwse.
Old 30-09-2004, 06:20 AM
dreday dreday is offline
im injecting at 4psi on a trd supercharged 1.8l
