Old 15-11-2004, 03:16 AM
Bill-Sims Bill-Sims is offline
Default Looking for recommendations for a supercharged Alfa
I run an Alfa 3 liter sedan in autocross, and am in process of fitting an Eaton M-62 supercharger. Engine has a modified Bosch L-Jetronic with larger AFM and larger injectors and reset parmeters. Is not "tuneable" by laptop. Planning on 5 to 6 psi boost. Car does a 1 minute run about 8 times/month, and I'm at WOT only about 15% of the time. Idles about 15 minutes in grid during each event.
Is not driven on the street.
Is the Aqua Mist 1S the best for my application? How much should I pay in USD? Who is a good source?
Thanks!
Bill Sims
Mandeville, Louisiana USA
Old 15-11-2004, 06:35 AM
Default The Alfa is running 10:1 compression
Forgot to mention the Alfa is running 10:1 compression. Heads have been prepped and has headers flowing into low restriction mufflers. Cams are very mild (Alfa 164S cams) for plenty of mid-range.
Does not have a knock sensor.
Bill Sims
