Old 07-08-2005, 08:10 PM
themadscientist themadscientist is offline
Default Averaging MAP and MAF for input to controller
I run a liner progressive controller in my car. I was thinking that because I run the stock turbo and need more cooling in the upper RPM range where the turbo blows the hottest air. I could just use the MAF voltage and that would follow RPM closely. But then I though about averaging MAP and MAF. That way I can run more boost through the whole RPM range and have more water when and where it is needed.
Am I insane? Or would this be a good idea? One big problem I can think of is isolation of the MAP and MAF signal lines.
TMS
Old 07-08-2005, 08:24 PM
I think you are very sensible, the intercooler efficient will also drop as well at high flow promoting more heat.
Old 08-08-2005, 10:38 AM
Do you think I should weight one more than the other?
TMS
Old 08-08-2005, 11:00 AM
TMS
The map sensor output will level off when the boost pressure reaches wastergate setting but the MAF will continue unless the flow exceeds the MAF sensing range.
Is it possible to incorporate a temperature sensor to modify the MAF sensor output?
Old 08-08-2005, 12:09 PM
TMS
That is my problem. The turbo cannot carry boost to redline. When the boost starts to fall off I get a reduction in the amount of water injected. When the boost starts to fall the heat in the charge starts to rise because the turbo can't flow enough air to keep the pressure up. So when I need the most water I am not getting it because the boost is falling off.
I was looking a a microcontroller for this, but then I found a passive circuit to average the voltages. I like to keep thing simple. How would you intergrate the temp sensor? Would you average all three MAP, MAF, and IAT after the IC? If it would be a straight average of the three the passive circuit could be used.
Old 08-08-2005, 02:07 PM
Here is a circuit you can rig up yourself for less than 5 dollars.
You need to find a temperture to suit your operating range.
Old 08-08-2005, 02:53 PM
That is the active one that I found. My only concern is that there will be cross talk between the signal lines. I tried to set up the passive version of that circuit today using 2 DC power supplies and a volt meter but the voltage readings did not jive with the average I should be getting.
I am leaning towards using a microcontroller like a STAMP that would allow me to give a weight to each input and would isolate each one from the other signals.
TMS
Old 08-08-2005, 03:47 PM
TMS
Try this one, no cross talk:
Old 08-08-2005, 08:17 PM
That was my next idea. Now I just need a quad opamp. I will see what I have at work tomorrow.
TMS
Old 08-08-2005, 08:38 PM
Slight improvement, you can switch off the sensors you don't need.
The LM324 shouldn't cost you more than 20 cent each.
