Old 03-10-2005, 07:28 AM
miata_rp miata_rp is offline
Default Choosing the right nozzle...again
Hello to Everyone,
I just installed an Aquamist 1s system and would appreciate help on the
most applicable nozzle for the following setup:
--Miata 1.6 L with a Jackson Racing Supercharger boost at 6Psi(.4 bar)
--Timing set at 12 deg BTDC
--Stock fuel injectors rated at 220 cc/min,
--An auxillary pressure regulator that is indexed to boost and at WOT
--is supposed to raise f/i pressure to the injectors at 80 psi.
I was trying to decipher the Aquamist graph to no avail as I can't figure out the flow rate for a .5 nozzle at 100 psi(7 bar).
I am using a .5 nozzle right now. With an Aquamist 100 psi race pump and with the stock injectors and AFPR what % water am I currently injecting.
Thanks for your help.
