Old 20-09-2007, 11:03 PM
maxc maxc is offline
Originally Posted by JohnA
Max,
Could you rephrase the question so it is clear what the options are?
So if the total air, gasoline, steam, mixture is say 150F it will not absorb any more heat?
It takes time for the heat in the combustion chamber from the previous combustion cycle to make it to the cooling system. We should take this over to In Cylinder Effects, sorry.
Old 21-09-2007, 08:08 AM
JohnA JohnA is offline
Are we talking pre-compressor temps or post-compressor?
Pre-comp doesn't make much difference, it will all turn to steam anyway
Post-compressor temp does matter a lot, but in any case it is unlikely to be able to generate steam. Just some heat exchange between the water droplets and the air.
In-cylinder is another story, it will all turn to steam because of the pressure/temp conditions.
What I was saying is that if the water has already turned to steam pre-comp, it has nothing left to do afterwards. :wink:
John
www.max-boost.co.uk
