I'm goign to be running my Aquamist 2c setup in conjunction with my Jim Wolf Tech Ecu.
I was thinking about mounting the pump and tank in the trunk of the car, however was unsure as to if that was to great a distance for the pump to push water (essentially from the trunk to just beneath the front passenger headlamp, where the intercooler pipe is. I wanted to mount the kit someplace near the actual pipe, however there is no room, this side of being exposed in the engine compartment (which I do not want) Any help is appreciated! Thanks! -Cody Ace
Cody Ace - 1997 240sx - SR20 Power - 400whp/330 ft lbs |
I mounted the Aquamist pump in the boot on my last car and it worked well, have done the same again with a Shurflo pump in my GTO.
Best point is I have a 20l tank in the boot which makes filling less frequent, just check the level everytime I fill the petrol tank up.
| Thread Tools | |
| Display Modes | |
