#11
This may sound silly, is the gauge switched on?
#12
nothing is silly at this point, but I tried the button on the gauges both ways, just to be sure.
#13
Changed the power supply source per our discussion, and the gauge appears to be working fine. Going to go out and run some water through it soon. |
#14
Please keep me updated.
#15
Well, went through the manual testing proceedure (thank goodness, as I hadn't put the fuse in), and everything seems ok. I have good water flow, and all the required lights are coming on. Took it for a drive and did a couple of full-throttle pulls. Everything seems ok, except partway through each pull, the Water Level led on the gauge comes on. Which is very odd, seeing as how I do not have the water level sensor hooked up.
Any thoughts? |
#16
On the HFS-6, the water level light has two functions. If you have not calibrated the failsafe window, the failsafe will trip and turn on the yellow led. But it resets after a preset period of 4 seconds (adjustable 2-6 second). Page15.4b (brief mention). I am working on adding a few more pages on the manual.
#17
Happy to report the system is now doing what it's supposed to. I haven't tuned anything in yet, but logged a quick pull on the way to work this morning. The intake air temp dropped 16.2 degrees F in 1.6 seconds. Love it.
#18
Good to know. Ambient temperature still in the 100s?
What are you running 50:50? We have a newer design inline valve for the HFS-6, high flow (1400cc+) and pressure up to 180psi. We have if you are running more than 2 jets, just let me know, I will make an exchange at no cost. We can now pushing the limit of seal material, closer tolerance, higher flow and response time.
#19
I'm going to be running 6 jets as soon as I find a spare intake manifold, so that would be great!
I'm going to start a new thread with my setup. :smile: |
#20
Re: no power to the gauge?
can you tell me more on this, I am having the same problem
