Old 06-05-2010, 12:28 AM
taiman taiman is offline
Default HFS-3 in EVO VI
Just added water and all this popped out
after understanding what everything is and does i came across this problem, the tank outlet was already in place and the pump inlet didnt agree with it.
so i bought 6mm push in fittings to do this.
Old 06-05-2010, 12:31 AM
Default Re: HFS-3 in EVO VI
drilling of injection points, just before the throttle body
loctite ing in place
lower coldside piping picture
Old 06-05-2010, 12:39 AM
from the boot to the outside
from the back to the front
FAV mounting, underneath the engine bay chassis rail
covering everything with split tube cable protectors
to be continued...
Old 09-05-2010, 06:21 AM
used velcro to make it stay
now just to mount the tank and tune
Old 09-05-2010, 09:28 AM
This install is well thought out. I didn't want to post earlier until you have finished. Congrets.
One the tank install, is there room for the level sensor?
Please test run the system before tuning.
Old 11-05-2010, 11:59 PM
thanks Richard,
if you have a closer look at the tank pictures, the level sensor is in place at the back end of the pump.
came pre-drilled and installed by Howerton Eng.
just waiting on anti-slosh foam now for further piece of mind.
