  #17
Old 23-05-2010, 07:51 PM
Canonshooter Canonshooter is offline
Default Re: Going with the HFS-3
This weekend I finished up the under-hood part of the HFS-3 install. This included installing the jet in the TMIC, installing the Fast Acting Valve (FAV), the water lines and the electrical work. All of the wires are now run into the passenger compartment for final hook up next weekend.
These two photos show the jet and hardware installed in the TMIC, on the under side of the outlet to the TB. Since the Perrin has cast aluminum end tanks, the drilling and tapping was very easy with plenty of material to tap. I sleeved the 4mm line with 3/6" fuel hose to protect it - on the second photo you can see it pull down over the barb fitting and secured with a zip tie;
The photo below show the FAV installed on the EBCS bracket;
Looking forward to "going live" next weekend!
