Old 10-08-2010, 03:56 AM
Shuasha Shuasha is offline
Default Failsafe activation on a Blitz SBC I-D iii
I've been messing with this for a bit. I have an HFS-5 and am wanting to configure the fail safe. It appears that the dual solenoid for this boost controller won't drop down to spring pressure when I cut power to it, in fact, it causes an overboost.
Does anybody have any experience with these dual solenoid units? My guess is that cutting the power to the unit will also cause an overboost condition.
Old 10-08-2010, 04:24 AM
Howerton Engineering
Default Re: Failsafe activation on a Blitz SBC I-D iii
Do you have a link to the manual?
Old 10-08-2010, 04:45 AM
I've found the v10, but not the v9 manual. It doesn't get into detail about EBC configs, only MBC's.
Old 10-08-2010, 04:54 AM
I'm interested in the Blitz manual.
Old 10-08-2010, 05:30 AM
Ahh, it's very basic.. just says to hook up the power and ground wires. It doesn't give a pin-out for the sub-harnesses.
http://www.blitzpowerusa.com/techsup...bc_i-d_iii.pdf
Old 10-08-2010, 05:47 AM
Just taking a quick look at it the controller has a scramble boost function that allows a temporary raising and lowering of boost. On some controllers this can be actuated by an optional harness and a wire rather than the control panel buttons on the unit. Other than hacking the existing harness, you would probably need to look into the scramble function/optional harness closer, or buy a secondary solenoid(MAC Valve) to dump boost to wastegate pressure.
Old 16-08-2010, 09:49 PM
Thanks for the valve guys. What's the best way to deploy this with an EBC?
Old 26-10-2010, 08:42 PM
nicky turboboy nicky turboboy is offline
jeff i run Icolor EBC and i used MAC valve to cut pressure signal into the dual niod box.
