  #14
Old 09-12-2011, 03:55 PM
Ngrabau Ngrabau is offline
Default Re: HFS-3 pump runs on after pull
I can't wait to see the old HFS-3 board.
The system could spray even when the valve was stuck open because the pump was not activated. Since the valve was not shut properly, you would see the prolong syray after lift off as the line was depressurising.
Well Jeff sent over another board the other day, I slapped it into the customer's car and everything works exactly as it should!
The old board is en route to CA for Jeff to look at, I assume it's next stop is England. I'm pretty curious to see what the problem is too, this one was a tough one. Thanks for all your help!
Nick
