Thread Tools | Display Modes |
... Switch is off on my gauge !
Very annoying as it will drain my battery. Please help Thx |
You must only connect the red wire of the grey harness to a switched +12V source: only active at the "pre-crank" key position. Read page 11 of the user manual again.
I have connected the wire to the Injector + as per the installation picture.
shall I change it a switched +12V source? |
This weird...
The entire HFS-3's power in control is activated by the red wire of the grey connector. As far as I know, the fuel injector (+) should not be "live" when you switch off the car. Is your car a factory standard. Just to certain, can you check the injector(+) for me to ensure there is no 12V present there when you switch the engine off.
I put it as you said on the 12 V source and it works fine.
Thx |
Has it solved the "car switch off" problem?
Yes it solve the problem. Thanks
