Old 06-03-2012, 05:42 PM
brightside brightside is offline
My kit just arrived today. can't wait to get home and open up the box! Install begins this weekend on the r56. going to try and take some pics of the process.
off-topoc
I'm thinking of routing the lines through the cabin.......how bad of an idea is it?
Old 06-03-2012, 07:36 PM
Thanks for the update. I hope you won't be disappointed.
I am not familiar with the mini but I am certin where are plenty of install on Jan's website. You will be the first HFS-4 equipped R56.
Old 11-03-2012, 10:39 PM
watsonj0 watsonj0 is offline
Got my Kit, the shop starting the install on my 996 turbo this week.
Old 12-03-2012, 10:35 PM
Do post some install pictures please.
Old 14-03-2012, 04:21 PM
hank49 hank49 is offline
I am interested in using braided steel hoses with my HFS-4. Do you offer these?
Thank you,
Hank
Old 14-03-2012, 04:23 PM
Jeff at www.howertonengineering.com offers this option.
Old 18-03-2012, 08:21 PM
Scooter09 Scooter09 is offline
off-topoc
I just ran mine through the cabin of my Clubman. I used it as an excuse to fix some rattles too. It took me THE ENTIRE DAY, I wanted to make sure I did a good job, so I took out the panels on both sides and the seats. I ran the power up the drivers side and the hose up the passenger side. I didn't want to do them both on the same side since the space for wire was so limited. It worked out great! It was just time consuming.
Old 18-03-2012, 11:46 PM
spoilboy1 spoilboy1 is offline
Can you post some pics.
Old 21-03-2012, 02:12 AM
aus jd 2703 aus jd 2703 is offline
ok ive always been keen to run WI on my GT four celica, but im curious. will WI gain me any power if i cannot re tune to take advantage of the increase knock resistance?
i run a stock non adjustable ecu with a water to air intercooler so intake temps even when hot never go past 60'c even in 35'c summer days. i like the idea of WI but at this stage am not sure i will see any real benefits?? thanks guys
Old 21-03-2012, 09:05 AM
Can you increase boost?
AFR will be leaner for sure but WI will welcome that. It appeared that you can push a few more psi quite safely with water/methanol injection, leaving the tune untouched.
