Old 08-05-2012, 02:45 AM
ldangelo ldangelo is offline
Default Recommend system for V12 Twin Turbo
I'm looking for system recommendations for a 2006 Mercedes CL65. The CL65 comes stock with a V12 bi-turbo stock tune produces about 600hp. I'm looking to cool the intake air temps to keep the ECU from pulling timing and boost when the inter coolers heat soak (which is often in Dallas during the summer)...
Once I get the IAT issues under control I plan on getting an ECU tune to bump timing and boost.
Any suggestions on which system would be best for my application? If I tune for methanol how do I protect my motor in the event the methanol system fails?
Thanks in advance,
-LeoD
Old 10-05-2012, 07:25 AM
Default Re: Recommend system for V12 Twin Turbo
The HFS3 or 4 will work well with your engine. Eoithe rsystem can cut boost down to wastegate upon failsafe activation.
