Old 06-06-2004, 02:32 PM
I can't remenber which system you have installed in your car.
For curising cooling, 2d can be switched on manually and it will injected a small amont of water as the duty cycle of the fuel injector during cruising is relatively small, it wouldn't consume too much water.
All you need to do is to break one of the connection to the 806-157 pressure switch.
