Originally Posted by Mr.b207gti
Hi Richard I seem to have a problem I cant get my kit to work, I got the wiring diagram form a friend showing were the injector+ is and the - is but not sure where to put the ecu red wire. Got it on fuse now and the the system is on the idc light is pulsing but my pump is not running not even if I do the fvb and sys test.! Dosent spray as well, when I drive the switch indicator flashes green but doesn't spray. Other thing is if I plug out the tank plug the light still stays green ?? No one here could help me so far been twice to the guy who sold me the kit and he doesn't know why, as he has not fitted hsf3 v2 to the 207 yet +27844306110 if u could help thanks please if you have the diagram for my 2010 207 Gti please send it to me so I check everything
For the 2010 207 Gti, you must use the "green harness" to read fuel idc.
Red wire to injector (+) and Green wire to injector (-)
As for the Grey harness, the red wire must be connected to a "switched 12V" at the "pre-crank" key position.
