Old 09-04-2013, 07:39 PM
slow ride slow ride is offline
Default Supercharged V8 and HFS-5
Hello,
I will be running the HFS-5 with DDS v10. I plan on using it with a hobbs switch to trigger at 8psi. I have an overdriven magnacharger (roots) making around 14 psi in my 6L Pontiac GTO. I have a couple questions:
I want to know what size jets I should use. I will be using 50/50 mix of meth and water on 93 octane and 57# injectors. The car will be making anywhere between 550-600whp. I tried using the a calculation chart, but I must be doing it incorrectly as my results are making no sense.
My other question is where should I mount my nozzles and how many nozzles do I need? Here is a picture of my setup:
Old 11-04-2013, 03:59 AM
Default Re: Supercharged V8 and HFS-5
bump...anyone?
Old 11-04-2013, 03:51 PM
You will probably need between 800-1400cc/min of water/meth. The final injection ratio to fuel would largely depend on how close is detonation when the engine reaches maximum power/boost.
