Old 05-06-2013, 06:33 PM
RennerMs RennerMs is offline
Default HFS-5 Inline flow control valve problem
Hi, I have installed the HFS-5 kit on a 2013 BMW 6. The pump is coming on underboost, the gauge doesn't recognize any flow. When I apply 12volts to the inline control valve, then the methanol goes through the flow sensor and the gauge recognizes it. I am getting 12volts on the terminal 1 and 2 at the control box. What problem do I have?
Thank you!
Old 05-06-2013, 09:16 PM
Default Re: HFS-5 Inline flow control valve problem
You may have a clogged flow sensor. What is the serial number? Some later ones are serviceable.
Old 06-06-2013, 05:16 PM
Hi, Richard! Thank you for your reply. Just to clarify something....
When there is methanol flowing through the flow sensor, the gauge is recognizing the flow. My problem is I am not getting the methanol past the inline flow control valve and I know the valve is good because when I apply 12volts to it, then the methanol goes through it, the flow sensor sees it and shows in on the gauge. Any other ideas?
Thanks for your help.
Old 06-06-2013, 07:35 PM
How did you active the valve before applying 12V to it.
Old 06-06-2013, 07:45 PM
I could not . The control box could not activate it. Terminal 1 and 2 both have 12volts.
Old 07-06-2013, 08:02 AM
Lets go back a step.
Which version of HFS5 do you have? Look at the controller box.
