Old 28-10-2014, 11:31 AM
stgan44 stgan44 is offline
Default GTR35 Wiring Diagram for HFS-3
Hi Richard,
Wondering can you help on this?
I am looking for a wiring diagram to fix on a HFS-3 on a Nissan GTR35.
I found one on goggle which show HFs-6 wiring application. I connect Pin 17 which show F.IDC(-),the pump will start to spray.
Can you advise is this wiring diagram not right?
Regards,
Gan(Singapore)
Old 29-10-2014, 02:48 AM
Default Re: GTR35 Wiring Diagram for HFS-3
have you checked this forum?
Old 28-11-2014, 03:05 AM
Hi Ricchard,
Thank for the info.I got it all wire up and face a new issue.
When we on the iginition,the pump start to on.
F-IDC,Thres and 95% IDC all light up.
What could be the problem?
Please help.Thank you
Gan
Old 28-11-2014, 08:52 AM
Make sure you connect the red wire of the grey harness to the correctly. If in doubt, connect it the fuel injector (+)
Which pin is the red wire wired to at the moment at the ECU?
