#11
I need to update the HFS3v3 soon. Meanwhile, you can use the wiring diagram below:
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2189
#12
Sorry to bring this back from the dead, but why cut boost and signal ECU? Can the ECU not do both? Just wondering...
#13
It wasn't clear, apologies, it was meant to be either/or.
#14
I had a short and an rechecking the wiring. The wiring of this diagram doesnt agree with the WRX ECU. I just measured current on each of the partially pink injector wires and all of them have a (+) signal, while your green wire states that it requires a (-) signal from the injector.
http://www.innovatemotorsports.com/r...ru_Impreza.php This shows the same thing. So is the polarity OK? Because I'm pretty sure most of the WRX if not all Impreza have a common ground and only "speed" (+) outputs to the ECU from their Injectors. |
#15
There is nothing wrong with either diagrams.
