22-03-2016, 04:57 PM
Re: Using water-only system year-round? Feedback?
Originally Posted by FI_Rubicon
I still plan to run methanol in the tank too. I ended up ordering three jets that I hope are sized for 50/50, washer fluid and pure water. I will just swap jet and tune when I swap the tank contents.
Or else if you have a custom ecu make a basemap for every mixture like I did !
When I run pure water, I can do that without bugging (or paying) my tuner for a new tune. The Diablosport Trinity allows me to modify my existing AFR-correct tune with up to 10 degrees of timing advance in three different RPM ranges.
Do you mean like a variable knob for fuel and ignition timing?
Don't want to fling any dung here but why bother with E85? My tuner said that if I wanted an e85 tune that he would end up richening the mixture and lowering the fuel economy and I would go through a tank of gas a lot more quickly than I already do. Jeeps with 37" tires already have a serious drinking problem as it is.
AGREED!
The tack that I am going go take is to tune for pure petrol in the fuel tank and a second tune for WM50.
AGREED!
