Old 08-06-2016, 08:13 PM
Onetechyguy Onetechyguy is offline
Default Gauge Dimmer?
I have the headlamp switch wired into a 12volt circuit right now, should that get wired into the dash light circuit so the gauge can dim with the dash lights?
Old 30-07-2016, 12:51 AM
Lolo La Torche Lolo La Torche is offline
Default Re: Gauge Dimmer?
also interested in this question
Does someone have the info?
Old 30-07-2016, 01:08 AM
Please excuse my poor english, but I'm not sure to understand what I have to do if I want my gauge to adapt to night or day conditions...
DIM: This trimmer works in conjunction with the head lamp switch. When it sees a 12V signal, the trimmer becomes active. This coincides with night drive conditions. The high- intensity led used on the dash gauge is too bright for night motoring. so wiring in the “purple wire” from the 4-way power plug to the head lamp switch is essential. Do not wire it to the car’s interior dimming circuit or unexpected results may occur.
Does it mean that I have to connect the purple wire to the black one of the gauge harness?
Old 31-07-2016, 07:40 PM
well, I now understand that i have to connect the purple wire to the 12V of the headlight switch.
Does it work with the blue dimming wire of the stereo (if I connect it to the purple wire)?
Old 31-07-2016, 08:31 PM
The 12V has to be a solid, dimmer circuit will not work.
Old 01-08-2016, 09:32 AM
Ok, i'll connect the 12v coming from headlamp switch to the purple wire
Thanks for all your help
