Old 30-11-2016, 07:07 AM
Default Re: No water level warning
short across the two wires (black and yellow) on the pump harness, it should trigger the yellow led on the gauge. If it doesn't, check for breaks.
Old 11-04-2017, 03:00 PM
Mr.202 Mr.202 is offline
I got the sensor working now, Only problem is when shifting and the car rocks, The next gear water level fail safe happens. Is there a easy way to make it less sensitive? just the float.
