Old 10-06-2017, 08:22 AM
Default Re: Map sensor or lack of?
I saw the voltage of 0.771v at the ECU. it is quite low for the MAP sensor. It should be around 1.5v at pre-crank. Also check the continuity of the blue wire of the grey harness because the the same voltage was not appearing the the RJ connector.
