Old 23-01-2018, 09:34 AM
Default Re: Injection amount vs E85
Been using allot of Richards systems recently (direct port) as per your finding and others works well, but I dont know everything, never will.
Anyway yours and everyone's contributions is what its about here and why its a good place, always fun to go back and re read some of the stuff from many years before too
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 23-01-2018, 11:03 AM
UCTURBO UCTURBO is offline
Because I have got a state of the art LT10s microtech which has no knock sensors, I have to read the plugs after each tune change, which Im happy to do. Ive never once heard my setup knock by ear but its showed on the plugs, although I have heard it knock just before the water turned on before but never once its on.
So just out of curiosity does anybody check the plugs? Or does everyone rely on knock sensors etc? Only reason I ask is I was always under the assumption that knock sensor wont show pre-ignition or at least not fast enough? Not that a plug check can help once the damage is done lol.
Here is an interesting read, unless Ive missed it I could find it on this site. Once it loads its a little down the page. Cheers
https://www.sciencedirect.com/scienc...7661021502648X
Old 23-01-2018, 02:23 PM
See the table set in my many Life Racing ECU customer cars, take note of title
NOTHING in the world is more fragile than a rotary engine!!!!
And with stock standard apex seals you can not break the engine due to knock, once set up correctly with a Life Racing F88 ECU.
I record every single engine cycle (all the time on load) and the ECU has always controlled this so each firing event of the plug each event of signal from the knock sensor is recorded but more importantly acted on INSTANTLY by the ECU.......... nothing in the world I have seen works as well, the other real racing quality ECU's I personally used and owned inc Pectel MQ12 and Bosch MS5* series ECU, shit that costs $20,000 for a control unit FYI no Mowreck or Microwreck need apply LOL.......
Old 23-01-2018, 10:20 PM
So it looks like not many people bother checking the plugs lol. You forgot microjunk and microwreck haha. Cheers
Old 23-01-2018, 11:00 PM
rotrex rotrex is offline
I pull them once in a while to check uniformity and look for absence of oil contamination, but if you push boundaries it might be worth doing it more often.
Otherwise the knock sensors, ears and wideband lambda sensors tell me what is going on.
For a turbo, you need at least EGT.
If you really want to know what is going on, add a turbine rev counter and pre and optionally post turbo pressure probes.
On the intake side, measure preturbo IAT and pressure. together with post turbo temp and pressure, you can see where you are on the compressor map.
If you run charge cooling, you could measure water inlet and outlet temp plus air inlet and outlet temp. This allows to calculate CC efficiency and figure out where the bottle neck is.
Old 24-01-2018, 01:30 AM
To actually hear knock from in the car, how bad does the knock count show? My car has 4 mufflers so its pretty quiet.
Old 24-01-2018, 08:44 AM
In a early Lotus Elise of the first series, you hear everything.
Can make you nervous after a big rebuild or power increase.
You can literally hear the injectors ticking at idle from the driver seat.
There is virtually no sound insulation, aluminium tub chassis, open top, mid engined. The "firewall" consists of a 3mm thick glass fibre sheet and you sit right in front of the engine for a RHD car and gain some extra 30cm distance in a LHD car. Seat mounts are short, seat padding is pretty thin, engine is partly mounted to the same alloy tub as the seat.
The engine/boot lid has big grilles to let the air out though the top. Noise also passes well. The lid is made from thin aluminium sheet and has no insulation material attached. High frequency noise easily exits the engine bay.
With a hard top or soft top fitted the cabin noise actually gets louder.
I have a radio installed, but past city speed it becomes pretty much useless. This is with a quiet muffler with its valve closed.
https://youtu.be/h-898etjgx0
Old 24-01-2018, 10:37 PM
Lightbulb Re: Injection amount vs E85
I am not sure what the delay is from sound generation inside combustion chamber then in air, then through various parts to your inner ear, process in your brain, then motor skills reaction and muscle movement to your leg but I would say well over 150 cycles of the engine would have happened at full revs before you can react.
Never mind that the audible knock/detonation event is much more intense that what I class a a pre ignition event trigger in the Life Racing ECU! So all up on some engine types you can say with 100% accuracy that is you are using knock ears or your own ear than that is about as archaic a method you can employ as a caveman to club a woman over the head for sex in his rape dungeon ............ sure you get the woman but she could be stone cold dead! some I guess it does not matter?
Many more minor events typically happen *unless you are totally wrong in calibration* or have some other part failure well before you get to pre ign or audible detonation, and the whole idea of well set up professional knock control is exactly that, you CONTROL it prior to it becoming a problem.
Never lost an engine on LR or Syvecs with my set up knock control, irrespective of root cause, loss of fuel pressure, poor fuel, some mechanical issue. Even this forum specific like latency of WI delivery say in 1st gear on a car capable of pulling 1.5g acceleration! with huge crank rpm acceleration rates and transient turbo response as per a light switch.
All of these things make it imperative that you run a proven ECU with correct knock control set up well, just my 2 cents on the topic.
Old 24-01-2018, 11:01 PM
Thumbs down Re: Injection amount vs E85
Here is a little sequence of events on time line to show you what I verbally described.
Keep in mind the ECU triggers instantly on register of knock despite what visual log threshold is set too, (in this cars case 300Hz is enough to capture the sound resonance through the block) even at 7500rpm on 4 stroke engine, you can see cycles recorded and event trigger of ign being pulled which instantly within one cycle of engine reduces knock........
All of this needs to be managed correctly to not allow run away knock and then pre ign from getting a foot hold and it happens so fast that there is no way in hell someone using knock ears will EVER catch let alone stop engine damage, the only reason they get away with it is the engine is either low stressed or is strong, its got nothing to do with skill or understanding (quality of equipment LOL) in them using 'knock monitoring' while tuning/fucking your engine and guessing what is happening to it under their supervision
Old 25-01-2018, 09:54 AM
I must be reading your graphs wrong but it looks like it starts knocking then pulls 3deg but the knock keeps going up even with the timing pull? How much knock have you seen to actually put aluminium on the porcelain of the spark plugs in a piston engine? Cheers
