| View Poll Results: Which would you choose? | |||
| Mix 87 and 93 depending on the season, and live with timing pull. |
	0 | 0% |
| Spend $900 on a flexfuel kit with tune, and mix 87 and E85 depending on the season. |
	0 | 0% |
| Install 4 0.3mm check valve jets in intake manifold. Activate at 50-75% of max boost. Run 87. |
	1 | 100.00% |
| Install pre-turbo nozzle. Run 87. |
	0 | 0% |
| Install bigger FMIC. Run 87. |
	0 | 0% |
| Multiple Choice Poll. Voters: 1. You may not vote on this poll | |||
	Thread Tools | Display Modes |
			I just purchased a 1.4L turbocharged vehicle that is tuned at the factory for 87 octane, but during the summer, will pull timing even on 93 due to knock.  I am not looking for “more power”, but simply looking to not have timing pulled.  I understand that 87 and performance don't mix, but the wife may be driving the car, so I want 87 as the baseline if she fills up.
	I am considering the following five choices. I own the necessary parts for the water/meth kit, as well as enough meth to keep the kit fed for 2 years.  |
			All water injection that actually does something, i.e. provides a high enough water to fuel ratio, needs a retune.
	Without adapted ignition timing, it will actually reduce power. You could add a FMIC spray as an alternative. This won’t require a retune. Flexfuel is also a good choice.  |
| Thread Tools | |
| Display Modes | |
