Is it feasible to utilise a fuel injection inline pump - running at 5.2 - 5.9 Bar ( Bosch K-Jet system for example) for WI? They should be cheap as chips from a scrappy and if it wears out in 6-12 months (and it probably will) I can just get a new one. The control unit, water level sensing, boost switching and possible 2 stage jetting is easy for me to sort out (once I figure out the sizes of jets to use), but I'm wondering if the system would still work with a fuel pump? The system is for a 306 Turbo Diesel which will eventually be running about 18-20 PSI of boost and I'm looking to cobble up an equivalent to the 1S system, but with water level sensing and boost cutting (back to 14-15PSI) in the event of water outages.
PS. The system will be running 12.5% meth/water max (as recommended for diesel by Richard L), would the pump handle this? Thanks Andy
A yard full of cars and not enough money......yet! (Oh, and a turbo diesel......sorry) There are 10 kinds of people; those who understand binary, and those who don't! |
![]() Quote:
YOu can get yourself a shourflo or flojet pump, they are relatively low cost.
Cheers for the gen Richard
Good point - well presented, rusting pumps may fail a bit too quick! :lol: Have to check out the shurflo and flojet pumps, if I can't find suppliers and costs you just know I'll be coming right back here to hassle you again! Ta for now Andy Edit. Found some suppliers Flojet 2130-112 (5.9 Bar 12v dc) ?130 +carriage & vat (http://www.dualpumps.co.uk/) Flojet 100psi ?118 + carriage & vat Aquatec 90psi ?95 + carriage & vat (both from http://www.reachandclean.co.uk/water_pumps.htm window washers!!) Still searching for Shurflo though Andy
Well, it is official.
I produce the mixture Water Methanol 50/50 in Italy for all clients that are in need... :lol: expecially the turbo diesel car with Aquamist!!! :lol: Regards. Daniele |
![]() Quote:
Cheers Richard, you are the oracle
![]() ![]() ![]() (Nobody need answer that.............. :lol: )
Hi dub... came here sorry for last night but it was 1 year i was blaming to get in the forum and just last night I was able to
Well about the pressure... it depends on which engine are you working on. |
Don't apologise, it's me who hi-jacked the thread, not you.
The engine is a 1.9 Ltr turbo diesel in a peugeot 306 It currently runs 14 PSI of boost, but will be wound up to 18-20 PSI for the Water injection. I'm trying to keep the cost down as nearly ?400 for a system is way too much - the cheapest 100 PSI pumps I can find are about ?150 If you can run an effective system at lower pressure I can sort out a cheaper pump. Building a simple control system is quite easy too. Is this enough information for you?
I work in bars... but I think that this is a common trouble to every diesel engine.. I think you're talking about 0.9 Bar... aren't you?
WI is currently working only when the boost is on. Be lower than boost pressure is impossible... even 18 - 20 PSI of WI boost is too little... at least 3 or 4 times the Turbo boost pressure, probably even more. Need to "atomize" the water in something that seems gas. I'm sorry but I don't know UK prices... I live in Italy... :sad: |
1 Bar = 14.50377 PSI so yes, 14 PSI is about 0.95 Bar
The boost is to be raised to around 1.3 or 1.4 Bar, so the pump needs to be 4.1 - 5.5 Bar (60-80PSI) It seems like I still need an good pump, but at least the 4-5 Bar pumps are cheaper than the 7 Bar ones (around 100PSI) Do you use a similar setup to the aquamist system '1S', just a pump, nozzle and boost switch - only pumping water when the boost is on (accelerating) with a fixed output (not changed to match fuel) and how do you get away with using 50/50 methanol to water if you still pump at 4-5 Bar when the aquamist pumps at 6 Bar and must use less than 20% meth to stop detonation? Grazie per la vostra assistenza (If that makes no sense then I had better keep to English :lol: ) the-dubster And there is no reason to be :sad: when you live in Italy ![]()
