Old 12-08-2005, 08:46 PM
sabreofsd sabreofsd is offline
I saw the picture of the SuperZilla turbo - wow.
I think the current issure with the aquamist/hydra is the relay contact resistance. It didn't appear the ground the map switch pin properly. I have sent Phil another junction box and see if it make any difference.
A real mystery to solve.
So when the fault is tripped on the Aquamist system, I presume that it is grounding a wire on the Hydra then? Was it a matter of grounding the wrong pin or the relay having trouble getting it to true ground? The Electrical Engineer in me would be very willing to help
Sabre (Julian)
The P in DCAWD
www.dcawd.com
WRB 04 STI: 97.73% Stock
More info here
