Im running a dual stage WI kit and want to be able to control the amont of water added at various revs so as not to saturate at low end. What is my best option. I have thought about replacing my jets with fuel injectors and using a AIC controller to adjust the duty cycle. What are peoples thoughts on this.
Scott ![]()
RX7 |
I have just seen this VCIM. I should think it would work with my cooling mist kit. Has anybody used this item or know of one which will work with my system
Scott
RX7 |
Do you want to vary voltage to your pump to vary water output?or 2 stage jet sizes?do you want to use the MAF sensor output,MAP output or throttle position sensor or engine rpm to determine water flow amount?I have a bunch of ideas/solutions/experienced people I can suggest--Todd
speez06@msn.com |
