Hello, I'm new to the forum. I would appreciated some advise on WI for a porsche 996 engine running 11.5 comp and 5-6 lbs boost
With an AEM ECU It seems to knock a little at max boost and 3-4000 rpm. At 6lbs the timing is 15 btdc, where normal timing would be 26-28 at 0 lbs. I don't know how much water/meth to inject? was planning to use a 2S or maybe 2C system. with these setting, I did a couple of dyno runs and was getting 350 hp at 6000 rpm with 11.5 AFR If I was smarter, I could calculate fuel delivery. but I was hoping for a starting point. Thanks, I know there are several questions in there. |
May I ask where are you located?
There are several 996 installed with a ywin pump system as the following link: http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=1004 I can send you a bit more details if you let me have yor email address: post your email address to richard@aquamist.co.uk Richard
Hello,.....Sorry, I activated the email in the profile.
I'm in chapel Hill NC the email is jhfair@med.unc.edu Thanks, Jeff |
