Old 29-05-2006, 01:41 AM
awdrocks awdrocks is offline
Originally Posted by JohnA
Wideband and EGT gauges compliment each other, the overlap is not large.
In my opinion, WB is higher up the priority list on a forced induction engine.
A decent way of knock detection is also very useful. On some engines KnockLink can be a useful instrument when fitted properly (may take time and experimentation though)
Be careful when using just EGT values for detecting lean conditions --- if you go very lean EGTs start dropping! It's easy to lose an engine from over-reliance on EGTs. They have to be interpreted in the context of the other parameters.
Right... I have a wideband and thats what I tune with. Im just wondering if it would be smart to get the EGT also. If im at a good A/F than there might not be any use to get an EGT.
If my A/F is perfect what can a EGT possibly be good for? What else can it help me with if my A/F is good?
304 Big Bore Longblock By Modular Performance
Car below:
http://forums.explorerx.com/index.ph...CODE=12&CID=44
