Old 29-02-2004, 05:39 AM
Anthony Anthony is offline
Default Water injection on an old 6.2?
Is installing water injection on my 82 6.2 worth the study and brain cells? I have used water injection on high compression gas engines but the diesel application is new. I used the vacuum drop of the gas engine to operate the injection. Since the diesel inherantly has no vacuum, how is this done?
I appreciate any advice.
Anthony
Old 11-03-2004, 08:51 PM
billg billg is offline
You will have to use a fogging nozzle and pump. From what I?ve read you want to stay around 10% to 15% of fuel rate and have enough pressure to stay above the boost levels (pump 60 to 100 psi). Here is a couple of sites that have some info on working it with a diesel.
http://www.aquamist.co.uk/cp/cp.html
http://www.snowperformance.net/products.asp?id=10
I've heard of some pretty impressive results from more than just one person.
2000 3500 Ram turbo diesel. Edge EZ, 4"turbo back and Trbo Master, Suncoast tranny
Old 20-03-2004, 02:06 PM
Sticks Sticks is offline
Your 6.2 in naturally aspirated isn't it? No turbo or intercooler?
If so, this may get a little tricky. It can still work, but you will need to use a small injector, and a throttle switch (set at 75% or higher) to activate the system.
Do you have an EGT gauge on your truck? That will assist you with your tuning, and show the results of the system a little better.
Sticks
02 Dodge 3500 5.9 Cummins, 3:54, 4x4, AFE Intake, US-Gear SD E-brake, PIF-EZ, PIF-Snow Performance W/M injection, Stage II fuel injectors
Will work for a hybrid turbo!
