Hi Richard,
I have no real way of testing the pressure right now. At the moment i am using only the devils own internal pressure switch. As an example, if the system is dry, when i turn on my ignition the pump will activate until it's reached it's required pressure, it will then turn off. When i activate the HSV the flow of water lowers the pressure which again activates the pump. This system has worked great so far, but i have purchased a Aquamist Single channel manifold, (erl.806-201). My plan was to fit this close to the HSV, i will then turn up the devils own pump pressure cut off switch so that for normal running the Aquamist manifold will turn the pump on and off depending on the pressure. Basically i'm wanting a system like the one shown below, but with a Devils own pump. ![]() My problem is though the Devils own pump has only 2 connections so how do i wire up the Aquamist Manifold/pressure switch? Cheers Mark |
