#161
![]() Quote:
Otherwise you might get an extra thick protection margin against detonation, but that's it. Usually at the expense of power. That's what most people do, and that's what most 'tuners' do, so they give W.I. a bad name (useless, expensive, band-aid, etc) They are still stuck in books from the seventies and eighties, or practices from days gone by. I have seen significant power gains with water/methanol injection both in the summer and the winter so it can be done. The concept works. |
#162
![]() Quote:
Is the MAF converter not going to be the way forward with WI on the astra ?
ASTRA COUPE TURBO |
#163
On the C20LET I had the ECU accepting the output from the AEM wideband.
Apart from it's own display of the wideband, it also had an output that could be set up to emulate the stock narrowband sensor. So the ECU was very happy. In fact it ran better than with the stock sensor, because the wideband moves quicker. |
#164
![]() Quote:
I could not continue on the dyno with Mike's car as the air fuel ratio along the plot was a bit irregular. But I think Mike is tempted to getting the Innovate lambda gauge, I will then be a bit more comportable with what the a/f ratio is during the next tune. I still think the MAF converter is the way forward rather getting a full blow piggyback ECU, cost wise. This is one thing which is very clear - trimming the MAF signal is a very simple way of leaning the air fuel ratio. I will contact Mike to find out if he want to continue.
#165
![]() Quote:
#166
![]() Quote:
#167
Richard - after looking at the innovatve products I look for alternatives and found this:
http://www.zeitronix.com/Products/zt2/zt2.htm It is the Zeitronix Zt-2 and seems to be a brilliant bit of kit and much cheaper too. What do you think of it? The user input can log any 0-5v signal so I was thinking about getting one of these to log knock: http://www.thor-racing.co.uk/KNOCK_BLOCK_-LNK_KNKB.asp I want to continue playing with the module. I fitted a new AFM today but it didn't feel like I got the power back. I logged the lambda (although only narrow band) and it stayed below 0.8, not sure how accurate it is. The second lambda sensor seemed to give fluctuating results (yes, there are two on this engine). I'll speak to Courtenays about this tomorrow. It may be that one of my lambda probes has gone funny. I'll get the car running 100% before we have another go with it. |
#168
![]() Quote:
72 samples per second per graph divided by 7 channels means 10 samples per second per input. It would ne nice if you have a few spare inputs. I know very little about knock sensors - the nice ones uses DSP chip to analyise the knock and the not so good ones just have a tunable notch filter. I welcome you getting some useful tools to help tuning your car. It is too dangerous to to tune without them or rollong road hours can mount up very quickly. Let me know when thing are back to normal again. If you have the wideband, you can check you MAF sensor daily.
#169
Richard - I am currently watching the videos on the inovative site. Err.... that thing is amazing!!! I think I.m changing my mind back towards this setup..... (3 more videos to watch!)
#170
![]() Quote:
Thread Tools | |
Display Modes | |
