![]() Quote:
In almost all turbo cars, it tends to run rich to so the fuel is used as a coolant. But rich a/f ratio also robs power. So if we can replace those extra fuel by water, it is the most ideal setup for water injection. The unit do just that. Water injection is effective on retaining your power in the summer by keeping the charge temperarture down but in winter, it tends to rob power due to over cooling. Reducing rich fuel mixture will allow more heat available for power. Does it make sense? Richard
What you are saying makes sence, but I'd like to see it thoughly tested beforeusing it on my car as I'm sur eyou know the consequences of running the car too lean at high boost.
![]() Quote:
After all, this what WI is originally designed for - replacing excess fuel. The above unit is quite safe, it reads the lambda and if it go lean, the voltage converter will switch off automatically. If the unit proved to be effective, might fit a DDS3 to monitor water flow. The unit is also capable of modifying the fuel in relationship with water flow adn well as monitoring the lambda at the same time.... This will be almost be 99% bullet proof. The unit is not expensibe to produce either. Richard
Here is a chart shows how the little unit work:
What connections will the maf converter need to the car ?
ASTRA COUPE TURBO |
![]() Quote:
1) 0V 2) +5V 3) +12V 4) MAF OUTPUT (0-5V) The converter splice ionto the cut MAF cable. We also use the +12V and 0V for powering the converter. Quite simple. Richard
![]() Quote:
ASTRA COUPE TURBO |
I have made provison on the prototype to sense the pressure switch of the 1s, when the 1s triggers, it will automatically start the conversion.
I have also made available an extra input to read the DDS3's flow signal (50-450cc/min) so the converter trims the fuel proportiional to water flow. All these facilities are waiting to be tested. I am still a bit tied up at present. The unit has already been made sometime ago but yet to find time to try it. It all work as intended on the beanch. Richard
![]() Quote:
Sorry Richard - I haven't been able to get those figures to you as my car has been of the road with a major electrical fault. Maybe you can help with your knowledge of electrics? See this post for more info:
http://www.migweb.co.uk/forums/showthread.php?t=244956 |
Thread Tools | |
Display Modes | |
