Old 04-03-2013, 09:27 PM
ysfg35 ysfg35 is offline
Default Re: 997 turbo .. something is going wrong
I tried to active the system today but the same issues i wrote you yesterday !!
But after i did some changes to the PWM unit from inside , it made the gauge not working at like yesterday , only the yellow light apeared in the gauge , then after 5 secs it off !!! So i think the gauge is damaged !!
Old 04-03-2013, 10:24 PM
1. Have you tried with the factory cable?
2. Unplug the blue harness and see if have made a difference (with original gauge cable) .
Old 04-03-2013, 10:52 PM
Well after the gauge became not working i tried everythings , i also now running the factory wire cable .. Still same issue !
And nothing !!! Am afraied that the gauge damaged and PWM is failed !!
I
Old 04-03-2013, 11:08 PM
You need to return the controller and gauge to us for repair. We don't charge but you have to pay shipping on both directions.
Email me: richard[at]aquamist.co.uk
Old 04-03-2013, 11:28 PM
Email was sent sir .. Thanks for your support
Old 17-03-2013, 09:21 PM
Both gauge and controller were severely damaged.
It makes no difference which version of HFS-3 you have in the past. It will do the same damage.
Old 15-04-2013, 08:38 AM
problem solved
we tried the system and it worked perfectly
big thanks to richard for his help
