Old 15-05-2013, 01:27 AM
Howerton Engineering
Default Re: Setting up failsafe issues
It won't stay tripped. The failsafe trips for 3-4 seconds then tries to reset itself.
Old 15-05-2013, 03:33 AM
rbamon rbamon is offline
When the B goes off, it comes back on less that quarter of a second later
Old 15-05-2013, 08:19 AM
There are two timers on the failsafe.
1. Transition delay timer (FSDL) .......... 0.2s - 0.6s.
2. Failsafe reset timer .......... ~3 seconds (fixed)
The Transition delay timer allows the flow signal to stablise before triggering a failsafe event. The start of the transition time is indicated by the onset of the B symbol. If fluid flow does not arrive inside the window area during this grace period, the failsafe will trip and reduce boost.
You can experiment of the FSDL trrimmer on the controller by extending of shorten this "grace" period.
Old 15-05-2013, 08:33 AM
But either way, why would it trip for a millisecond at best? Once it trips should it not stay tripped? The B always comes back on immediately after going off
Old 15-05-2013, 08:34 AM
I did think about the FSDL but wasnt sure it would help
Old 15-05-2013, 08:36 PM
I think you may be confused with the function of the "B". B does not indicate a failsafe trip.
B comes on at the start of an injection event (when threshold is reached). It stays on about 100mS + FSDL, during this time the flow signal must be inside the window area. If it does, the 3-second failsafe will trip and drop boost.
B (100mS) + FSDL allows the flow signal to stabilise so the false alarm will be minimised.
If you cannot get the WL to trip, rotate the WL clockwise or decrease the FSDL.
Old 16-05-2013, 10:30 AM
Thanks Richard, looks like ill need to adjust the delay as having WL even full clockwise wont trigger it
Old 16-05-2013, 12:37 PM
There must be something wrong with the WL trimmer. I will send you some instruction how to test it. It will be on the gauge.
Old 16-05-2013, 12:58 PM
Ok, thanks Richard
Tags
fail safe, failsafe, hsf4, problems
