Old 06-01-2014, 04:24 PM
Default Re: LSJ Cobalt/Ion Redline ECU pinout
- Top picture ............ ecotec product (from link)
- Bottom picture .......... googled. It has three port.
I think they are the same valve. One with dust guard
Can you tell me where the ports is connected to:
a ...... assume to atmosphere?
b ...... ?
c ...... ?
Old 06-01-2014, 06:55 PM
Dust Dust is offline
C is atmosphere, hence the dust guard in first pic
A connects to the intake manifold and B connects to the bottom port of the "SC bypass actuator". The electric connection on "A" side faces the back of the car. The coworker that was supposed to help me with the car took off before lunch so it will be after work before I can tell you the connections, although from the pic it seems like there is only two.
Old 06-01-2014, 09:49 PM
I think I have enough information to produce a wiring diagram for your car. Give me a few day.
If available, can your source a ECU wiring diagram and a picture of the PCM (pin out side)? You have already provided the pin out.
Old 06-01-2014, 10:27 PM
http://cobaltss.net/resources/pcm/05cobalt20.htm
Almost the same, but the high speed from 1 and 2 aren't there for the Redline from what I am reading. Here is the Redline pinout
http://www.redlineforums.com/forums/...et-better.html
Old 06-01-2014, 11:01 PM
Please check the diagram below is correct.
Old 06-01-2014, 11:04 PM
I have all those diagrams already. I like to see the wiring outside the PCM and may be an image of the PCM itself.
Old 06-01-2014, 11:59 PM
Is this the correct PCM?
Old 07-01-2014, 02:44 AM
That looks like it.
Between the fuse box and BOV. LSJ, but turboed. Leaves more space in that area to see it.
This is the next generation of the engine, but it has a much better pic of the PCM.
Look in the middle of this picture at the blue piece. That is the elctric connection for the solenoid above.
Old 07-01-2014, 03:24 AM
And should your first 29 in the diagram you made be 33?
Old 07-01-2014, 09:29 AM
Sorry, made the correction. I will make the H4/LSJ wiring drawing as soon as I can.
