used gtech meter. ignition timing, cam timing, fuel etc.. all is left as it is yes.
![]() Quote:
Do you want to share with us in detail what the setup is about as the video is too dark to see well ? |
![]() Quote:
Cam lobe wore out in that engine. The next build the power valve leaked on cam breakin 5 minutes into it blowing blue smoke out the tail pipes. I no longer use carbs with power valves. Don't have money for fuel injection. |
![]() Quote:
See my #7 post in this thread. Simple gravity feed boiler with reservoir mounted on firewall solenoid turning on .030 jet too boiler. I never ran carb booster venturi feed setup.
