Old 06-05-2005, 03:08 PM
Roverdose Roverdose is offline
Sorry that I have not made clear. The Nitro itself has 50% fuel and 50% oxygen combined it doesn't need extra oxygen or extra fuel to support its burn.
The reason for adding 20% methanol to it is to ensure that it burns on the "rich" side.
ahh i may well have miss read it.
would the nitro have the same cooling effects as water when injected into the air stream?
Drew
Old 06-05-2005, 05:55 PM
cuprabaz cuprabaz is offline
Thanks for that. :wink:
Think i'll be leaving well alone for now until i make my first million!!
Bigger IC and Nitrous looks like the best option.
230bhp & 230lbf-ft
Custom remap by STAR PERFORMANCE
Old 07-05-2005, 12:47 PM
any problems with nitro running through a 0.3 jet?
considering using direct port on the nitro.
Drew
Old 10-05-2005, 10:28 AM
well i just bought a 2nd hand aquamist with dds2.
can one pump handle 4 x0.3 jets and can i run that from 1 hsv?
will i need to replace the seals in the pump?
Drew
Old 10-05-2005, 11:04 AM
Yes, each 0.3mm jet flow 75cc/min. On HSV and one pump is perfect.
You must also order a 30um inline filter and used as a secondary filter after the main 100um filter. This is because the 0.3mm jet has a 25um filter inbuilt and will clog up quickly if you don't have the pre-filter.
Old 12-05-2005, 12:15 PM
will nitromethane attack aluminium?
Drew
Old 16-05-2005, 10:05 AM
I will drop a piece of ali into the nitro for you and tellyou the result in a few days.
Old 16-05-2005, 11:15 AM
cool, i have a spare alu tank that i dont want to use for the water/methanol mix, just wondering if i can use it for the nitromethane instead.
Drew
Old 17-05-2005, 05:13 PM
Wet1 Wet1 is offline
Hmmm...
Old 17-05-2005, 05:30 PM
Why compromise, inject 100% nitro!!!
:twisted: :twisted: :twisted: :twisted:
I don;t think you need water in the mix. Get a separate system purely for nitro and leave the WI alone. It might be useful to suppress detonation if nitro induces it.
I think you can get a low cost water injection for that purpose. Hotrod and I both agreeed that you will get about 3-4 hp/100cc/minute. if you are aiming for 30-40 HP, go for injection rate of 1000cc/min. In drag racing terms, a 10-second pass will only use up 180cc of nitro - pretty cheap fun - cheaper if you only inject after 1/8th mile.
