#101
Hey guys
![]() Quick Q about wiring in the HFS-3 to an EVO 7 JDM ECU. In the Diagram it shows a red, green and a pink wire to go in to the ECU harness. However the RJ-45 cable supplied does not have a pink wire ![]() ![]() |
#102
^^^I think the orangy looking wire is the pink one....
I am installing my hfs3 in my evo8 atm and having some problems with getting the pump to prime...did it work well for you? |
#103
![]() Quote:
Our apology.
#104
Richard :
lol, no apology needed ![]() ![]() daymean : Sorry mate, I have not tried to turn the system on yet as my engine is still not in the car. When its back in I will let you know ![]() Also I will have lots of pics of the install. |
#105
X2 both Richard and Jeff @ Howerton.
#106
hey guys, back to bother you again
![]() I finished the wiring for the control units power and I can only get the one LED to light up. Is this because I have not filled the tanks for the first time yet ? I am still putting the motor back in but all the sensors and wiring is done. I read the manual and saw it should come on after 5-10 secs ? what am I missing ![]() ![]() ![]() ![]()
ಠ_ಠ 2001 EVOLUTION VII - 2.4L + AQUAMIST
#107
Disconnect the water level sensor and try again.
The system will not start up if the tank is empty.
#108
problem solved. thank you muchly
#109
Hey Richard,
When setting up the Sensor calibration, should this be done with the jumpers in test mode, while the car is stationary? |
#110
It has to be done on the road to be certain.
I suggest 10 clicks on WL and WH from ZERO. Set the SC to 12 o'clock Let me knwo how many bar you are seeing with this setting. Where are you located Richard
