Old 29-11-2005, 11:51 PM
Rootzz06 Rootzz06 is offline
Are you guys running this through your alky injection kit or mixed with your gasoline in tank?
Old 29-11-2005, 11:59 PM
I think it is mostly manifold injection type.
Old 30-11-2005, 12:00 AM
EvoTio EvoTio is offline
water injection mix.
Old 27-02-2006, 08:28 PM
meansrt meansrt is offline
Default RC car fuel clogged up my system ....
The lubricant clogged my filter , pump , and injectors. Nitro is a great power boost , but not with the lube in it.
Old 27-02-2006, 10:20 PM
what system are you using?
Old 28-02-2006, 02:52 AM
Default Was a Coolingmist Deluxe Dual Stage ..... But ,
I'll be installing a Engine Runup kit this Thursday .... MUCH better !!!
http://www.enginerunup.com/index.php
Old 23-03-2006, 11:58 PM
sdminus sdminus is offline
Has there been anymore development. Im thinking of trying but nitrometane seems to be a controlled substance at the mo as well as methanol
Scott
RX7
Old 25-03-2006, 06:58 PM
I had my first play todqay with differant chemicals. I had a play with a 10 %mix of nitro as found a small perfrmance gain. It was mixed with methanol which made my afrs go a big crazy.
Scott
RX7
Old 25-03-2006, 08:47 PM
You are about a have a great deal of fun from now on. just run nitro and methanol 50/50.
Old 25-03-2006, 08:51 PM
i was thinking of going a bit higher but not thought of that. It so far with the meth has richened up my afr by a lot. more than the same run on 100% meth. does this seem normal across the board. Ive gone from a nice 12.5 to 11 afr from 0 vac to 15 psi to 10.5 - 10.3 all across the boost areas. This would give it huge potential for tuning.
Scott
RX7
