4" inlet on the turbo.
You get the full specs on the tank when you get the kit ![]() The rear tires are 255 wide good street tires, they do get pretty shredded in 2nd gear so I leave the traction control on to limit tire wear, 3rd gear now they are having a hard time also, but generally now I just leave the car in 4th gear (from 80kph to ~240kph) it has more than enough torque *red spread of power* to pin you back at any revs/speed, using third to overtake is pointless as its over in less than 2 seconds and you are either about to fly off the highway! or literally drill into the back of another car ![]()
Get On It!
:-Oc==3
http://www.riceracing.com.au RICESP > F40 > Zonda > ZR1 Water Injection Specialist "Can't be defeated!, don't know the word!, shoulder to shoulder!, we'll fight the world!, WE CAN'T BE BEATEN!!!" Last edited by RICE RACING; 23-07-2011 at 01:57 AM. |
She has passed the 1.8kg/cm durability tests with flying colors
![]() ![]() The acceleration is gag factor to the max! it's not scary but I tell you it does make your arsehole pulsate in mild fear if you have not sampled this kind of thing recently.......... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
This just keeps on getting better and better!
Very nice car and that engine bay stays like new always!!!! |
![]() Quote:
![]() I remember reading in one of my text books from my engineering days on the development of BMW's 4cyl turbo F1 motors where Gordon Murray (Brabham/BMW designer at that time) basically said their whole program was in the firing line after a couple of years trying to go turbo, and in the end it was something so small and relatively stupid that either made it work or not (ended up being a simple calibration setting!)...... *Moral there* Lets not forget how miserably Ford Cosworth failed in attempting to make a 4cyl turbo to match BMW's at even half the power let alone 1300+bhp I have my own little (by comparison) developments, and its all part of the challenge to develop something no one else can and do it on far less, its not the cubic dollars that makes the difference just a great concept (WATER INJECTION) applied well, and set up to achieve what its always shown through history to achieve, the best power, with minimum stress, and all on common parts (be they mechanical *engine* or chemical *fuel*) Hope it inspires people to follow what Sir Harry Ricardo and other great engineers have bestowed generations ago
http://www.riceracing.com.au RICESP > F40 > Zonda > ZR1 Water Injection Specialist "Can't be defeated!, don't know the word!, shoulder to shoulder!, we'll fight the world!, WE CAN'T BE BEATEN!!!" Last edited by RICE RACING; 26-04-2011 at 12:43 AM. |
I was inspired when i stumbled upon this forum by chance,in fact i was researching a bit on water/meth injection.
Then midway i figured that you are not a trader over here but a real enthusiast...haha! What you have done so far is truly amazing,hope you will carry on with the good work and keep us scotched to the screen with your achievements! Will seek some tips later when i get into this. |
![]() Quote:
![]() I have been using RICESP as the daily drive now *till my new tow car arrives!*, as well as weekend cruiser (just came back from a 200km 3+hours scenic lunch drive ![]() ![]()
I have been reading about the nozzle type you are using, and was wondering if the nozzles could be used with a pump feeding the water side, and only boost feeding the air side?
I guess you could do that (I have never tried it). It would defeat the purpose of the system to be "simple" using an electric pump, + you would have to put in allot of work with PWM control of the valve to meter the water in (which is basically self regulating with boost pressure feeding the water). Hope that makes sense to you.
I was thinking about using my current kit, and using the new nozzles to reduce the micron size for the turbo's ingestion. Don't know how much it would help though.
