Old 04-04-2005, 04:31 PM
PuntoRex PuntoRex is offline
Default Re: My pictures
Originally Posted by hotrod
..... He injects directly on the compressor shaft nut with a narrow jet. The rapidly spinning shaft nut simply blasts the water stream into a fine cloud. .....
Larry,
Is it possible to have a picture about how he install the whole thing?
I guess it'd be pretty similar to Richard's proposal above.
But, how can we deal with the restriction to the airflow & the fixing reliability?
Yet another idea, the supporting spoke can be designed as a set of "wings" to be a fixed turbine. Can this be done, or has any advantages? (sorry for the naive imagination on the aerodynamic)
'97 Fiat Punto GT
Old 04-04-2005, 07:40 PM
Default hub injection
I've never seen the installation but it is explained in some detail in another forum : (posts are about 2 years old)
http://www.eng-tips.com/viewthread.cfm?qid=72284
Look for the posts made by " turbododge " --- I haven't figured out a way to invite this guy over here yet, as I don't see any sort of a private messaging system on the eng-tips forum --- maybe I'm missing something, but I would like to see him join this thread if he happens to browse this forum under a different username.
================== quick summary of his key posts ======
turbododge (Automotive)
30 Oct 03 19:51
I just got referred to this thread by a friend and being a long time user of water injection thought you all may be interested in what I have personally seen over the years. I run a twin turbo, now EFI (was carb), twin turbo 340 Mopar in a 70 Cahllenger, strictly street, 14 psi boost, intercooled.
I use an old Edelbrock Varijection system that has been altered for instant on under boost conditions at 7 psi. It varies the amount of water based on rpm and absolute manifold pressure. It does not have adequate pressure to spray directly into a pressurized intake manifold, so I spray directly on the turbine blades. The turbos are lower than the inlet ducting to the throttle body, so even if I have a valve failure, I cannot water slug the engine. I have run this system for over 15 years on carbed and EFI turbo engines, and would not go without water injection. I can run 8 to 1 compression at 14 psi on 92 octane all day without worrying about detonation.
I find the talk about atomization, hummidty, where the water evaporates, etc to be very interesting, as I have watched my system extensively over the years. When I spray on the turbine blades, the water (with 50% isopropyl) vaporizes instantly, before it even touches the blades. I have 50K mile turbos that show no erosion at all, and even the intercooler does not get any significant amount of moisture in it. The ductwork all stays dry. The low pressure area at the turbine inlet easliy evaporates the water spray. I found no difference with EFI or blow thru carb in this respect.
When I was running a suck through carb setup, I was spraying directly into the carb throat with the water, and found that the carb venturi would vaporize the water right along with the fuel from the venturi. Subsequent running through the turbo also further atomized both elements. All was good unless the inlet ducting was cold enough to condense out the fuel and slug the engine.
In an N/A engine, you would spray straight into the carb with most systems like a Spearco. An Aquamist you could go into the manifold below the carb as they atomize better, but most folks don't do that. Unless you are dumping very large amounts of water into the carb, it will atomize, if it did not, it would build up in the intake and give a big slug to the engine when you turned, etc, and probably thermal shock or hydraulic the engine to distruction. I think it would be a very risky business to try to get, or count on getting unvaporized water into the cylinder.
As far as the power is concerned. As I mentioned before, my setup is instant on, off a pressure switch, or an override switch in the cockpit. I have done lots of testing at boost levels to 12 psi (max without detonation without water) with the water on and off. I give people rides and turn the water on and off, then off and on to see if they can feel the accelleration rate change. I can tell you that no one has ever not been able to tell that the water came on and the accelleration rate increased. It is very significant. I would be surprised, however, if you would be able to readily feel the difference in an N/A engine, as when I turn the water on and off while holding the boost down with the throttle, I cannot feel a difference at all, in my low compression engine.
My net conclusion is that on a boosted car above 10 psi, water injection is necessary if you want to be able to run decent compression, timing, and mixtures, plus you will get more power do to charge cooling, even if you are intercooled. On an N/A car, I would use water only if you need it to kill detonation because of high compression, bad gas, etc. I don't believe it would give you enough more power to notice.
31 Oct 03 0:18
Turboice: You are absolutely correct in that one big factor with water injection is killing the detonation to allow you optimize other conditions. It is very common in the turbo crowd to try to drown the detonation with extra fuel, even down to 10 to 1 A/F. All it does is cost power and give minimal results. The is a very good chart in the Hugh MacInnis book Turbochargers on the affects of water on detonation, boost level and air fuel ratio. One look at the chart and you can become a water booster for life.
Concerning the non erosion of my blades, it may have to do with the fact that my water only comes on when I really need it, so it is on a very small % of the time, but I am also very carefull to send the nozzle stream (it is not atomized) at the CENTER of the compressor shaft so that any impact is on a slower speed, less critical area, and the water flow moves out the blade rather than impacting it. Also, with Varijection, there is less water at lower rpms and boost levels and more at higher speeds and boost. A single output volume, set to deliver enough water at full load, like a Spearco, can easily overwhelm a turbo spinning at lower rpm and impact the blades harder. With the EFI controlling spark and A/F (12.5 A/F under boost)and careful tuning of the water we normally will only use a gallon of water per 1 to 2K miles of street driving, as we are good to 10 psi very safely without any water, (and 12 if the gas is good). So putting is enough water to get to 14 psi is pretty easy.
31 Oct 03 12:40
The erosion of the blades discussion is very interesting, and may apply to others differently than me. I am running plain old T04, oil cooled turbos, and have been for many years. The newer turbos with the aforementioned lighter blades and perhaps more brittle alloys may be more of a problem. With those I have no experience. There was a post that mentioned someone who had a friend who did get blade erosion (post probably gotted whacked because it referenced another site). Was this person, by any chance, running a water/methanol mix in his system? From what I have seen and heard, methanol will take out turbine blades, throttle body plates and bearings, and can even corrode the tips of fuel injectors enough to cause pattern problems. That is why I use Isopropyl in mine.
In thread http://www.eng-tips.com/viewthread.cfm?qid=82878
5 Jan 04 18:51
I have been injecting water/isopropyl alcohol on the turbine blades of my twin turbo 340 Mopar for 15 years now. This kind of system was very popular in the past, as it was much more difficult then to inject into the boost stream because of the high pressure. The blade erosion issue has always come up in discussion, but the only ones I have seen that had problems were either on stationary units that ran the injection constantly, instead of only under boost like in a street car, or if they used methanol in the injected liquid. Methanol is much more corrosive than isopropyl. My turbos have over 40K miles on them with no signs of erosion at all. I use about 1 gallon of water/isopropyl mix per 1000 miles. My system is also variable with speed and boost, so I don't overload the airstream with too much liquid at any time. It also atomizes better if you aim a single spray nozzle directly at the shaft of the turbine, the liquid usually is totally vaporized by the time it is 1/4" from the nut on my setup.
I can run with or without the water very easily, and if I am holding a boost level and turn on the water, you feel a very positive increase in accelleration. I am also running an intercooler, so this is beyond the intercooling affects.
If you do a good job of setting up the system, I would not be afraid to inject ahead of the turbo, as I have seen very good results that way.
7 Jan 04 0:01
Yes definitely on the compressor wheel, poor phraseology on my part.
I am not up on the viscosity/vapor pressure etc with methanol vs isopropyl, but I know I have seen methanol systems corrode the compressor wheel, but never an isopropyl setup do the same. Downstream corrosion is even more of a problem with with methanol, and I have even seen corroded throttle shafts stick in the carb base. Intercoolers will also sometimes condense out a small amount of water or alcohol in cold weather and the methanol will also go work on the intercooler. I would guess that the compressor gets wet enough with the methanol someplace along the line, either at cold start, cold idle or such. The corrosion I have seen covered more of the depth of the blade than impingement damage which tended to be very close to the entrance edges of the blades.
The other thing that goes with this is that all the other systems that had problems with corrosion also were on/off, non variable, systems, which can heavily overload the compressor at low rpms, cool air conditions. I have literally seen liquid drip from the compressor housing hose connections after a run.
I am sure there are lots of folks that have successfully run methanol in their setups, but for me the isopropyl makes it much easier and more reliable, with very little downside.
7 Jan 04 20:36
Overrange: We drive the car a lot, but spend a very, very small percent of the time at throttle positions that would turn on the water. If we do a 500 mile "cruise" through the countryside, it is very possible that we will not use any water at all. My system does not come on until 8 psi of boost, (out of 14psi maximum),and since the system matches water flow to boost and rpm, water flow at that point is quite low. I can tell you that a 340 CID V8 will accellerate very quickly at 7 psi, and it is easy to stay within that range by controlling the throttle. To use the full 14 psi on the street requires a very good road in a remote area as the tires can go loose at any time, in any of the first 3 of 5 gears, depending on the traction. Even if the water does come on, it is only on for 10 or so seconds per use (maximum) before you are way over 100 mph. If I am testing and tuning, I have used a much as a quart in a day.
Although I did not mention it earlier, as the question I was addressing was the feasibility of injecting into the compressor, is that my system is not primarily used for inlet charge cooling, as I have an intercooler for that. My system is to allow me to run decent boost, without detonating, on 92 octane pump gas. Without the water I will get detonation at 10 to 12 psi, depending on the gas and weather conditions. It takes much less water to reduce detonation (as long as you have an intercooler to cool the air) than it does to cool the air enough to make power. That said, if I run up to 10 psi with the water turned off, and then turn it on, you can feel the car pull harder, so I am either gaining from cooling of the air further, or because of a better combustion process in the cyliders. I don't know what it is, but you sure can tell if the water is on or off.
The car also has a very good cold air system on it that takes air in through the boxed wheelwells that a fed from spoiler ducts, with only 6" of ducting before the turbos, after the large K & N filters.
As you can see by the above he sprays a solid stream directly on the compressor shaft nut, and allows the spinning compressor nut to beat the stream into a microfine mist moving radially outward. His system is in my estimation an ideal case of wet compression as there is no time for the water mist to evaporatively cool the air stream before it arrives at the compressor, but it will modify the compression due to the high presence of water in the air flow.
I on the other hand needed to maximize the density increase due to air charge cooling pre-compressor to get the most out of my undersized turbo.
I might add that I am not too concerned with his observations about methanol corrosion as he was obviously talking about setups that grossly over injected fluid and kept the intake tract wet all the time. Any system like mine that only comes on intermittently at high air flow demands will quickly dry out any condensate in the intercooler etc. That is one of the reasons I turn my system off in cold weather. I don't need the detonation suppression when the weather is cold ( I don't run high boost when its snowy and icy out ).
Perhaps a little of both would be best one very small spray jet well back from the compressor with some sort of a dropplet trap to keep any but smallest dropplets from passing into the compressor, and a hub injection setup to get the advantages of wet compression.
The other obvious question is are some of us willing to consider the turbo compressor a wear part and to plan on replacing it on a regular basis? I know many of the hard core performance nuts upgrade turbos on a very frequent basis, and for them replacing a $40 compressor wheel (or what ever they cost) every 2 years would not be a big deal in exchange for the performance advantages. I'm sure the WRC folks or people that compete in similar levels of competition would have no problems at all with that sort of replacement cycle. Serious drag racers might go through several clutches, a couple rear ends and a motor or two every year. A little R&R on the turbo compressor is not that big a deal in the grand scheme of things.
Old 04-04-2005, 08:41 PM
masterp2 masterp2 is offline
Default Re: hub injection
[quote="hotrod"]
I agree, why don't you get your density contribution post IC instead of pre-turbo, the convention? I am planning a 2 stager. Variable post IC, plus the boost activated 2nd stage pre-turbo (for when you just can't have enough!)
I just took a look at trying to get close to the diesel turbo, not going to be easy. There is a 90 only 5 inches from the blades. The upside to not requiring fine atomization, is that the nozzle doesn't have to be finely engineered. Mybe that will prevent some clogs???
Old 04-04-2005, 10:53 PM
Default special case
There are two reasons!
1.) In the first case when I started experimenting with this, I was trying to maximize the performance of a stock undersized turbo just to see what was possible. The only way to increase mass flow in a system in choke flow, is to increase the upstream density. It will still be choked to the local sonic air speed at the critical flow point, but with the increase in density, mass flow will still go up slightly.
2.) Due to my living at 5800+ ft altitude (and can easily reach over 12,000 ft altitude in an hour or so of driving) every turbo that is currently on the market is working far outside its design compressor map at these altitudes. At max boost, I am not on the far right side of the compressor map, I am completely off the page to the right. The intake cooling and wet compression pushes my operating point back toward the left.
Old 04-04-2005, 11:29 PM
Greenv8s Greenv8s is offline
Default Re: special case
:lol:
Peter Humphries (and a green V8S)
Old 05-04-2005, 01:44 AM
Larry do you feel you have been successful in humidifying the slug of air in the 50 milliseconds it spends between filter and turbo inlet? Can you support that?
just my opinion that with these coarse sprays, and so little residence time, that nearly no evaporation actually occurs, especially considering the low water/alc temps used. Maybe you can change my mind.
Flash swirl sounds like what you need to explore. What do you think? swamp cooler?
Old 05-04-2005, 08:01 PM
Default evaporation
Interesting question --- My short answer is enough to make a useful difference.
The objective is NOT to humidify the air, the objective is to increase engine (and in this case turbocharger performance) due to the sum of multiple effects. One of which happens to be evaporative cooling.
After considering you question for a while here's my view.
First very very small amounts of evaporation are all that are necessary to make a major change in the inlet conditions of the turbocharger. The specific heat of the intake air is .25 Cal/gm deg C (give or take a bit) while the latent heat of evaporation of water is 540 Cal / gm.
The maximum intake air flow on the stock WRX turbocharger is approximately 360 CFM or about 25.2 lbs / min ( 0.42) lb/sec or about 191 grams /second.
If you are spraying at a rate of 4 gallons / hour that is approximately 4.2 grams/second of water.
If you lower the intake air by 11 degrees Farenheight or about 6 deg Centigrade you increase the air density by 1% which will give you an increased mass flow through the turbocharger of approximately the same and give a net power increase (all else being about equal) of 1%. On a 250 hp engine then, each 6 deg C drop in intake temp is worth about 2.5 hp.
Given the ratio between the specific heat of air and the latent heat of water you have to evaporte only a very small fraction of the water to bring down the intake air temp significantly. Lots of people have recorded intake air temp drops on the order of 30 - 50 deg F (17 - 28 deg C) with initial air temps near 105 deg F (40 deg C).
So just to persue your question lets look at what we know. The air flows at a rate of 360 CFM max in an intake tube of 2.5 inch ID --- this gives a peak air speed at redline of about 176 ft/second (120 mph). The spray nozzle is about 2 ft away upstream so flight time for the dropplets are on the order of 11.4 milliseconds.
Now how many drops are in that air column and what is their surface area?
One cubic centimeter of water in the form of 50 micron dropplets (if my numbers are right) consists of about 424 million dropplets with a total surface area of about 333.3 cm^2. We are spraying at a rate of 4 gal/hr or 4.2 cm^3 / second so we are putting about 1,780 million dropplets into the airstream per second, they have an effective lifetime of 11.4 milliseconds in the air column, so the air column at any moment contains about 0.0477 cm^3 of spray or 20.44 million dropplets with a total surface area of 15.9 cm^2. Plus we also have the evaporation that occurs off the wetted interior surface of the tube, which would amount to 1216 cm^2 of surface.
How much water evaporates every 11.4 milliseconds, from 1232 cm^2 of water surface when exposed to a 120 mph wind ??
That intake air column has an air volume of only 0.068 cubic ft, which converts to about 2.166 grams of air, it obviously only takes a miniscule amount of evaporation during that 11.4 millisecond flight time to make a huge change in the temperature of a slug of air that only weighs 2.166 grams.
To lower that 2.166 grams of air 6 deg C, you only require .54166 calories of energy per deg C. To get that amount of cooling by evaporation of water you only need to evaporate 0.001 gm of water in 11.4 milliseconds/ deg C, or 0.08799 grams per second/ deg C which equals .5279 grams of water evaporated per second for a 6 deg C intake air temp drop.
{ all this ignoring the higher volatility of the alcohol component and its lower latent heat of evaporation but --- lets keep it simple for discucussion sake}
The interesting thing about this exercise is that it is obvious that the wetted surface of the intake tract dominates the evaporative cooling process by a large margin over the cooling that takes place at the dropplet surfaces.
Your swap cooler comment is right on target, and I have been considering similar ideas. It might be useful to intentionally maximize the wetted intake surface both to gain this cooling and to capture large mist dropplets.
I have considered putting pieces of fine mesh brass or stainless steel screen wire placed at extremely oblique angles to the air flow. (intention to give a very large open surface area but little or no direct path through the screen) Any dropplets that couldn't make the "jog" due to their large size, as they approached a screen wire would be broken up and wet the screen wire surface. Smaller dropplets would simply pass through the screen unmolested.
In a perfect design the screen would be treated so it wetted well with water alcohol mixes and had high capillary attraction to pull liquid water up off the floor of the intake and into the air stream. This is basically what is done inside heatpipes.
Old 05-04-2005, 09:38 PM
I started down the road to verify your numbers and it suddenly occured to me... I'll get to that. First, nice quantifiable arguments, as always. What I say in no way detracts from your well explained facts, but something is left out. Nowhere really do you represent where there is a reason for the liquid to evaporate. There is no "driving force" equation representing the change of state. You could have a billion droplets at -500 C and all the exposure in the world will still require an ice-age of time to evaporate (sublime) them.
Yes we have heard of 30-60 F drops, but not with ambient air, heated air (that is also dry). Ambient air at 80F will evaporate water at 80F, and if the air is 60% RH, it may take minutes, not milliseconds, to change state of a fraction of it. Perry's or the CRC might be worth looking at. See in an environment where compressed heated air (post-IC) is plentiful at 5% RH, there is a much greater force evaporating the liquid. But what you said, about the wall exposure was brilliant, and maybe breakthrough.
Here in Sunny Phoenix, I can lose 1/2" of water out of my 90 degree pool on a windy 115 F DAY. Yet not notice any loss, after a week of calm winter weather, with 50 degree air and water temps. Naturally if the water was at boiling, air at 100C, I could evaporate the whole pool in hours.
What quickly became obvious to me is this: a lightweight droplet, entrained in a moving column of moist cool air, is going nowhere (except through the compressor). Ah hah! The moisture on the wall has nowhere to go but to humidify. (the assumption that the entire conduit wall is wet is optomistic without a system settup to make it wet, one nozzle isn't up to the task, agree?) Without some nice dry hot air blowing past the drop, it quickly retires to a fate of drift, until it is exposed the hot, dry, dynamic conditions that are waiting downstream.
Keeping clear that anything that increases the apparent restriction in the plumbing is not going to work. It WILL kill the performance sought in the form of pressure drop. Screens and such in the column will not be a solution, without drasticly changing the conduit dimensions. 176 ft/s is not the place to add any kind of change, since as we know, most hood ornaments will be cast off at that speed, certainly flies don't survive it.
FWIW, I grant some evaporation can occur post filter, but this must be so miniscule as to be negligible. Swamp cooling that much air, done in a conventional way requires square meters of wicking material, and a puller fan that will wreak hovoc on your alternator. The pressure drop across swamp cooler pads is significant, and the process is not an on-off process. It takes minutes to wet the pads befor they start providing the desired result, etc.
What does come to mind, is along what he have discussed, with a twist. A 1/8" perforated SS tube that runs the much of the length of the conduit, concentrically. Ever seen a soaker hose? each .008" perforation a pseudo-nozzle, maybe 10-20 of them depending on flow requirements. You could even put a nozzle on the end of it, pointed into the blades.
What it might do for you is keep the wall lightly wetted, and still provide for airborne mist, and a direct inject nozzle. Manufacturing it, without significant restriction, will have to be a different book.
Old 05-04-2005, 11:37 PM
Default Real world conditions.
Well your comments are interesting, but I feel there is plenty of driving force.
Typical conditions here at the strip or on a hot summer day, outside air,measured well away from the pavement 85 deg F, at 12% humidity. I frequently measure actual intake air temps above 105 deg F.
That puts the intake air humidity as it passes the spray nozzle in the dry air catagory with a dew point of less than -39 deg F.
At dew points like that with pure water your wetbulb temperture would be about 53 deg F. (ie this is the temperature the air would cool to if you raised it to 100% RH by evaporation of water)
This is ignoring the issue of alcohol evaporation or the lower air pressure which makes the water have a higher relative vapor pressure.
The relative air speed between the dropplets and the intake air being in the 100 mph plus range will result in a nearly instantanous evaporation of enough water to drop the air temp by 10's of degrees F.
Its difficult to measure the true air temp because of problems caused by wetting of the surface of the temperature probe, but there is absolutely no doubt that there is a very large driving force for evaporation when the dry air and the rapidly depressurized water dropplets first encounter each other at high relative velocities.
If you want to dig through Perry's or CRC handbooks to figure out the realtive vapor pressures and all that ---- please do ---- I have neither the time or the interest in trying to validate what is obvious to me based on my experience. When going to the pre-compressor water spray, my midrange boost onset was so dramatically improved I had to change my driving style to keep from running over people when accelerating from stop lights. I'd come into boost so quickly I had to change my boost controller settings (turn them down) for daily driving.
Simple proof of driving force for water evaporation when your car is mass flow limited for air by the choke flow capacity of the turbo.
Without water spray in the intake car goes x mph in 1/4 mile, with water spray pre-compressor car goes y mph in 1/4 mile.
x is > than y ----- spray must work!
Old 05-04-2005, 11:57 PM
OK, I buy it. What do you think of the spray bar/tube idea?
