Old 28-03-2006, 01:38 AM
Solar_Subaru Solar_Subaru is offline
Default Hello All and windshield squirter diesel injection
Hey Folks! Nice to meet you all, this is my first time on this forum. I hope to have many conversations with everone, as I know there is trmendous potential in Water/Meth injection.
My very first problem I could you some guidance on is:
I have just poked a hole in my turbo inlet tube on my IDI 92 jetta ecodiesel. I stuck a handmade jet into the hole and plumbed it into the washer pump.
I had previously messed with the injection pump (all mechanical) and have been running about 15 psi boost under full load. When I hit the washer switch, it adds 3-4 psi of boost, and a more than noticeable kick. Of course I was very excited about this easy performance mod.
Then I heard the noise...Sounds like the engine is detonating? I didn't even know this was possible in a diesel? I have also been told on the Megasquirt Fuel Injection Forum that I will probably chew up the compressor blade with the water/meth (windshield washer fluid) spraying right into the turbo like that. Some have suggested that the noise is cominf from the turbo, I really think it is piston slap noise. Once when I turned the injection pump way up, and the car was pulling hard, I thought I had heard this noise. but a clutch failure and the fact that the engine wouldn't idle back down made me turn it back. but for a moment I had almost 30 psi on this little 1.6.
Anyhow, Is the water into the compressor going to chew up the wheel? and is it possible I am hearing detonation? I'll tell you, the fuel economy and extra power is very addictive.
Tony
92 Ecodiesel Jetta
69 Subaru Sambar electric conversion
75 Chevy Cosworth Vega Turbo
88 Megasquirt Toyota Pickup
