Now what about the by-pass? Is it needed? |
What do I need to do to have the pump run at 150psi and how do I modify the MAP switch to start @ xx psi? Since I am adding the RRWR I am just going to have it turn on and increase water directly referencing boost. |
I need to send you a non-by-pass assembly if you have already purchased the system. If you have not , we can supply a pre-assembled pump + system from factory.
Please ensure you have a RRFPR pre-calibrated to 125psi - this will allow you to go up to 150 psi during 25psi boost. Richard
Thx for the heads up on the RRFPR. |
