#11
If I am following your thoughts: 1-Check for voltage drops between inj+ and fusebox +, this difference might be highier then your limit allows. 2-Take the +12v from the fusebox currently powering up my DDS3 and connect it to my fuel injection ecu switched power. Is this correct? Thank You |
#12
Update to above. There is a 1.2 voltage drop between the +injector signal from ecu and fusebox cable pin 24 Will there be any advantage taking +15 or switched key voltage from ecu to correct this concern?? It looks like we are too far apart from your desired threshold. What are your thoughts? Thank You for your support. |
#13
Basically, it will work well if you move the DDS3 power in to the fuel injector +. This way, the difference will be much cloaser to each other. I can modify the DDS3 for you to allow the bigger volatge drop at your injector. At present it is 0.5V but I increase it to 5-6V. No rcharge, just need you to send the DDS3 Junction board back to me.
#14
It will be very simple for me to tap into the +feed for the injector and see what results occur. Question and concern:: What is the power consumtion of the DDS3 box? My concern will there be too much taken from the + signal of injector and ecu. Please Advise. |
#15
#16
I have rewired the +12v for the dds3 directly off of the ecu power up supply and have the following observation: 1-The flow gage has a hard time to start up, the illumination is flickering then a few seconds later gage is running. 2- The inj/idc led is lit up all the time. 3-When trying to run test mode the flow gage shuts on and off with no flow meter working. Yellow led is on all the time. Please advise. |
#17
By moving the DDS3 12V source to the injector supply rail, the start-up timer will be interfered with by a large amount of spike and quiet a bit of noise ripples.
I think we can solve this problem by sendng you a modified v10 board and upon receiving and successful install, return the board to us by USPS in your own time. I therefore need your postal address by pm. I will airmail you a v10 tomorrow. Richard
#18
PM has been sent
#19
Just a matter of interest, did the person who you bought the system from had this problem?
#20
